Map Update - July 13th, 2023
BubCam
Bub
I noticed that there is a new update 2021 Kia Telluride Map Update172U5W B date July 13th, 2023. Kinda unusual time for an update at this time. I tried three times to download and install, I get the notice that my file is corrupt or not there. There are files on the thumb drive.
Has any one tried to load to download and install successfully?
I don't even see that option you posted on my "Navigation Updater"...however, the SW and Map version on your post suggest that this is the same or even older that the last May 2023 update.
see below...
Speaking of Navagation, what are the dotted lines on the map?
If this is the line you’re referring to, it’s a direct line from your current location to the destination you are currently navigating to.
Thanks for the prompt reply. But what is it for? In case you break down and have to walk the shortest route?
My best guess is just to give you an idea of your ultimate path vs the direction the road is currently taking you.
