Pedal Tuner: Pedal Commander
xcelir8kia
Have had pedal tuners before on other vehicles with success.
Recently installed the Pedal Commander as it took only a few minutes. Hooked it up to my phone with BT and App. Set it to Sport Mode while trying it out on the KIA comfort and sport settings.
Really resolves throttle lag and makes the vehicle exciting again.
You can pick it up on their web site and or Amazon as I did.
Easy install. One 10mm bolt, and one 10mm nut. Easy peasy.
Good luck and have fun!
Congrats! Definitely noticeable when you press on the gas.
How is the result with Pedal Commander different from using the Telluride Sport Mode?
Thanks
Throttle plate opens faster equals massive improvement in throttle response.
Sport mode holds gears only.
