Need advice on replacing broken back up lense cover on 2021 Telluride
jaysawyer
I backed into a pole and broke the red/white lense cover of the back up light. The bulb is still working. How do I get the lense cover off? I have found a replacement cover on Ebay (I think). Do you just use a plastic tool or screw driver and pop off the plastic base or the cover itself? Thanks.
Removal​
  1. Remove the rear bumper assembly.
    (Refer to Body - "Rear Bumper Assembly")
  1. Disconnect the back-up lamp connector (A).
3. Remove the back-up lamp (A) after removing the screws
The clearance to do that job is bad. I had a difficult time swapping the original bulb for an LED. The photo above makes it look like there is a lot of room, there is not.
