I’d love to buy one if available? But I can’t ever seem to send you a message. Dayzah@att.net
Hi, I'm very interested as the part is only available for models until 2022.5 and I'm driving a 2024 and the sound is very, very bad.Yes, you would just cut into this harness for your install instead of the factory wiring. If you plan to keep your aftermarket equipment when you finally move on from your Telly, simply remove this harness and plug the factory connector back into the amp and it's right back to stock.
There was a min quantity purchase for the connectors so I do have extra parts on-hand to make a couple more harnesses if there is any interest out there in the community.
I'll be happy to Venmo or Zelle you.Yes, you would just cut into this harness for your install instead of the factory wiring. If you plan to keep your aftermarket equipment when you finally move on from your Telly, simply remove this harness and plug the factory connector back into the amp and it's right back to stock.
Like others here I am reluctant to cut/tap into the factory wiring for the audio system and since I could not find one commercially available yet, I went ahead and made my own breakout harness for the Harman Kardon amplifier in my SX. I plan to install a new amp/dsp in a few months and this was the first step in my process. Bottom line it permits installation of aftermarket audio components without cutting/tapping of factory wires while also maintaining full use of that same factory wiring for speakers (we've seen elsewhere the challenges of running new speaker wire out into the doors). Thus far it works flawlessly with all channels intact for this particular connector...the center channel and front tweeter channels are located on the 2nd amp connector (w/inputs, pwr, gnd, etc), but I do not plan to use those in my future setup (disabled and crossover, respectively).
Just to clarify, is this harness adapter for factory head unit output to amplifier input or is it for amplifier output to speakers?Like others here I am reluctant to cut/tap into the factory wiring for the audio system and since I could not find one commercially available yet, I went ahead and made my own breakout harness for the Harman Kardon amplifier in my SX. I plan to install a new amp/dsp in a few months and this was the first step in my process. Bottom line it permits installation of aftermarket audio components without cutting/tapping of factory wires while also maintaining full use of that same factory wiring for speakers (we've seen elsewhere the challenges of running new speaker wire out into the doors). Thus far it works flawlessly with all channels intact for this particular connector...the center channel and front tweeter channels are located on the 2nd amp connector (w/inputs, pwr, gnd, etc), but I do not plan to use those in my future setup (disabled and crossover, respectively).
This is for the H/K amp outputs, so speaker level. It's called a "breakout" harness so you can directly tap it for signal or add aftermarket components AFTER the H/K amp while still having the option to utilize all the stock wiring.Just to clarify, is this harness adapter for factory head unit output to amplifier input or is it for amplifier output to speakers?
I would like to purchase. Please message meThis is for the H/K amp outputs, so speaker level. It's called a "breakout" harness so you can directly tap it for signal or add aftermarket components AFTER the H/K amp while still having the option to utilize all the stock wiring.
@HLXHLX I'd also be interested in a breakout harness if they are still available. I have a Helix DSP and a couple Stereo Integrity amps I may try to install if they don't go in my other car.This is for the H/K amp outputs, so speaker level. It's called a "breakout" harness so you can directly tap it for signal or add aftermarket components AFTER the H/K amp while still having the option to utilize all the stock wiring.
