Modem Signal / Kia Connect Commands Not Working
irishbrahmin
Indiana
All:
I'm loving my '24 SX-P X-Line except for one issue.
Kia Connect isn't working. The Telly won't receive remote commands-either from the app or the website. The app also shows the Telly's correct location intermittently. I tried the typical head unit reset, app reinstall, etc., with no success. So I called Kia Connect. We discovered that the modem's signal strength /RSSI sensitivity is low (around -90 dBM). The agent told me that this is somewhat common with a lot of new Kias. So they've opened a case and will be in touch. Meanwhile, I took the car to the dealership and asked the service dept. to disconnect the negative battery cable for a few minutes to see if that'd help. They did so, and the modem went to a normal sensitivity for awhile (-60 dBM), but revered back to -90 dBM within 15 mins. Meanwhile, the Kia signal shows between 2-5 bars depending on location.
Kia Connect tells me that firmware could possibly fix this issue, but we'll have to wait and see what the technical staff says. The agent feels bad and told me that Kia will offer me some compensation once the problem is resolved. She mentioned that without me asking, which I thought was really awesome.
A bit of surfing reveals that some non-Telly Kia owners have had modem replacements.
As far as I can tell, this issue is only affecting Kia Connect commands. Sirius, real-time live traffic, phone, remote start with the FOB, etc., are all working perfectly. Those are the biggies for me.
Question: If it turns out that the only fix is a modem replacement, I'm wondering if it's worth it. I probably wouldn't renew Kia Connect after the free first year. Also, I'm fearful that fiddling with the dash to replace the radio/modem risks getting my Telly back with rattles and creaks. So far, this Telly is completely quiet--free of rattles and creaks (which wasn't true for my previous Tellys). Rattles and creaks drive me crazy!
Thanks!
i think im having the same issue. i have a red circle through my reception bar icon and none of the kia connect menu settings are functional. is this what you saw?
I have the same issue. I did the Navigation update in September and haven't been able to use the Kia Connect features since then (remote start, lock, unlock etc). I called support but they told me to take it in. I will update when I get some details.
its been fixed as of yesterday! open up the nav updater app and download the latest version. when you try to install it in the car, it will say its the same, but install it anyway and in 30 mins it will be fixed!
Ok I'll try that and update you on it. Thanks!
Hey. I just wanted to say thanks for the advice. That worked. Although, I had to download the update on a Windows Laptop. I downloaded it from a Macbook after you told me to redownload the update, but it still had the issue with the Modem not working. Then I used a Windows Laptop to download the update and finally got the Kia modem to connect. Thanks again!
Np. I lost alot of respect for kia though after I showed the error to the dealership and they quoted me a $7000 head unit replacement to fix the error. It was a very lazy and slimy move
Agreed. They are just out for the money. Mine asked me to leave my car with them because they couldn't figure out what the issue is. And it's crazy that an update can turn off the modem like that. But yeah totally agree that's a slimy move
I also have the same problem. The dealership quoted me at least $1,200 + tax. Definitely better than $7000, but still slimy considering my Telly is only 2 yrs old.
