Rear Camera stays on when shifting to Drive
mtcsox
Hi all,
I have a 2021 Telluride SX. When I shift from reverse to drive, my rear camera stays engaged for almost a full minute. Anyone else have this issue?
The rear camera should never be on when in drive on an SX. It should switch to the front camera, which would say on until you exceed 10 mph.
Sounds like something is broken somewhere if the camera doesn’t switch and go away quickly.
You could try resetting (rebooting) the system with the pinhole by the volume knob.
Go setup
Display
Then extended rear view monitor
And un check the box
That’s only a setting for cars with just a rear view camera. The SX has the 360º camera system, so the rear view camera will never be on in drive since it’ll switch over to the front camera.
My rear camera always stays on when I'm in drive. For at least 30s to a minute or more
Read my original response again. If you have an SX, this is not normal operation.
