Yes camera the dealership said 3 of the 6 were damagedWhat did you do to piss them off
Seriously, it's generally cylinder walls that get SCORED, not pistons. How were you able to find out? Camera?
147000Shouldn't be an issue unless you have over 100K on the clock !!
Did you change oil.@5000 miles intervals2020 Telluride burning oil. Just found out 3 of the pistons are scorned.
I am doing 5k right now may lower it to every 4K.Did you change oil.@5000 miles intervals
At this rate I may have to at every 2500 milesI am doing 5k right now may lower it to every 4K.
I may have to start doing that every thousand milesI am doing 5k right now may lower it to every 4K.
Do you check oil level with the dipstick when motor is cold?I am doing 5k right now may lower it to every 4K.
No warmDo you check oil level with the dipstick when motor is cold?
I was using OEM from the dealership. Think I am going to start using Purolator oil filters .Also are you using a quality oil filter?
To get an accurate reading I check it before I start the car when it is cold.Im wondering why you have the piston scoring.Im thinking perhaps the oil level has been low?Also,you did not mention what year Telluride you have.No warm
I honestly question the competence (honesty) of a dealershipAlso,I would get a second opinion.The car is out of warranty.I would check with a mechanic that is familiar with the car
Something else you can do is have an oil sample analyzed at a lab.I have heard it only costs about 50.They can also tell if there atec metal particles in the oil.I honestly dont believe the dealer used a camera to evaluate2020 Telluride burning oil. Just found out 3 of the pistons are scorned.
I was thinking about your situation.I believe 2020 wss the first year for the Telluride.It usually is not a good idea to buy a product in its first year,as problems show up and they try to correct them in subsequent years.Someone else had a similar problem with the 2020.He is selling his car and buying another one (not a 2020 Telluride)![]()
Oil Analysis | Blackstone Laboratories
Learn what's going on in your engine with oil analysis. Our free kits are easy to use and we explain the results in plain English! Since 1985.www.blackstone-labs.com
