Idle Stop & Go (ISG system)
Absolutely! I installed one within a couple of months of getting the car. It just works. Zero issues and take just a few minutes to install.
How to install??
You pry up the trim cover around the ISG switch, unlatch the connector underneath the switch, and connect the Autostop Eliminator. It’s pretty straightforward.
Go here:
Click the “installation” tab and there’s a video.
You can do the same thing by pushing a round tooth pick beside the turn off button all the way down and breaking off the top.
Or use anything that holds the button pressed by friction. A cut short zip tie works. Is free and can be removed in a second.
One wonders why anyone would spend $100 on something when free alternatives are around?
or just press the button to turn it off like the way you press start button every time to start the car. Takes extra 1 sec but is free.
Are you all not worried that installing the eliminator will void some warranty?
I would seriously doubt it. The only good that comes out of this is a slight uptick in MPG. This helps Hyundai/Kia with CAFE numbers.
It also will bring about more warranty work (read free) for KIA when marginal starters are involved. They could give a rats A$$.
This. The engine shutting off bothered me so much I just made pressing the switch part of my vehicle starting routine. Start the engine, press the IGS button, drive.
