Questions on battery
Amati5
Lots of questions:
2022 (bought in July 21), 31k miles, 4.5 yrs
1. So I decided to use the auto-stop again (had it jammed locked) function and it almost never work. Checked the battery with a device and it showed quality=0, charged 79% (after 20 mile trip), crank test=normal. The car has no problem starting or any symptoms. Is my battery going out? Also, Google said it might going in protected mode (what is it) Is our battery flat plate or spiral wound AGM?
2. I thought AGM should last much longer than typical flooded. My Prius AGM (Bosch) lasted like 8 yrs.
3. How long does basic warranty cover the battery? I’d rather buy my own without the hassle of bringing it the dealer, but just curious. Most other cars warranty is only 3 yrs and usually the battery lasts longer.
THX
I expect & get ( 5 ) years out of an OEM battery.
Too new to Tellurides, ( April 2024 ), to tell what their battery life is.
As far as battery warranty, it's whatever the Mfg. states they will cover..
Update: drove the car over an hr yesterday, mostly highway speed. This morning IGS started working. I thought the battery got better but it still showed 1% quality and “Replace” recommended. Still no symptoms of a weak battery. I read that’s the characteristics of AGM batteries, no indication of failure until it’s just stops working. I guess it’s time to get replacement. Carrying a Gooloo in the car just in case.
I've taken the libetrty to highlight part of your update. Thanks BTW.
Yes COMPLETELY. Since the switchover to AGM batteries and better charging strategies, we found at my shop that when any AGM gets near replacement than can/will fail without any warning.
Older lead/acid (flooded) batteries would give you plenty of warning with a few slow cranks and the sublininal message: "Hey buddy, maybe you'd better get me a replacement?"
The reverse is true for an AGM. Typically my customers would start the car, drive to Starbucks bereft of any issue. Only to come back out and find it dead with a; No crank, no start condition. every last drop gets out of the bottle.
Thx for the confirmation.
