Steve in Denver
- Nov 3, 2019
I'm in Denver (if you couldn't tell by my screen name), and we got dumped on last night. In my neck of the woods we have had about 12" so far based on the few measurements I made.
My Telluride is AWD, and I happened to have a fresh set of snow tires sitting at the Discount Tire right up the road. So this morning I was able to do a back to back comparison with the stock (michelin) tires vs Cooper Discoverer True North tires. Both are essentially brand new (1200 miles on the Michelins) And for fun, I also took out my Subaru Outback (2016) which has some Nokian WR G4 tires mounted.
For those not familiar with the WR G4 tires, they are "all weather" tires (emphatically not "all season") which basically means they are meant to be used year round (so none of the super soft rubber like true winter tires), but are designed to work well in snow and ice. My previous comparisons show that they are *significantly* better than all season tires in snow/ice, and actually approach the performance of lower tier winter tires (like the General Altimax), but good winter tires are clearly superior, at least in some conditions)
So, preliminary impressions...
The Telluride does pretty well in the snow (factory tires) with the AWD lock mode engaged (I didn't spend much time with it off, so I can't really comment on the difference it makes). I was able to easily get out of my neighborhood, which was a mix of totally fresh snow in some places, light tracks in some places, and then on the main drag out it had seen a fair amount of traffic. I could tell there was "something" going on with the AWD / ABS system when starting from a stop (and getting some slip) as it would "engage" in some way that would improve traction. I think it's the abs / torque vectoring function like my Subaru has. It didn't provide the smoothest experience, but it was definitely effective. I was doing about the same, maybe a little better, than the other AWD (Pilot, Highlander, etc) vehicles around me. Ice (compressed, frozen snow-slush) was more difficult, but not in a "I might get stuck" kind of way, more of a "I can't accelerate and brake as fast as I want." I saw more than a few cars (FWD in most cases, I think) that were truly stuck, or had lost confidence in trying to move.
I had done a good amount of research and landed on Cooper Discoverer True North tires. My experience with Blizzaks was that they wore out too fast (they are incredible tires, though)...In my research I learned that, in Europe anyway, winter tires are divided into two groups...I think "Nordic" and "European" or "Nordic" and "Alpine" are the labels I have seen used....I think, more or less, the Nordic tires are meant to be used where you will encounter snow / ice the majority of the time, where the "European" or "Alpine" tires are meant to be used in mixed conditions...dry roads in warmer temperatures sometimes, with some periods of snow or ice...which is what we get in Denver. I might have the labels or details about the tires a bit wrong, but the point is not all winter tires are created equal (and it's not just whether they can be studded or not) So I avoided Blizzaks (they seem more like a Nordic tire based on my experience) and similarly stayed away from the Nokians and other similar tires. I'm not really sure that the Coopers are better in this regard (longer treadlife when driving on dry pavement) but that's what I'm hoping for (without giving up too much winter performance)
So, after the winter tires I had the same reaction I always do. Holy shit! Winter tires definitely make a huge difference. Ice (again, compressed/frozen snow-slush type of ice) traction was much improved, snow traction as well. Stopping was significantly improved, as was turning. The AWD system didn't have to actively intervene much (at all?) once the snow tires were on. I went wherever I wanted to go. The main limiting factor was snow depth. The only time I thought I might get stuck (and I didn't really come close) is when the snow was high enough that I started "floating" (and at times I was plowing through enough snow that it covered the windshield and I couldn't see). It really worked well and inspired confidence.
As a comparison point (and with a car I'm much more familiar with) I drove the Subaru with the WR G4 tires...I didn't go in the deepest snow (I'm afraid I might get stuck, not sure of the ground clearance), and although it didn't have true snow tires, it did really well, too. The Subaru was not as sure footed (it felt floaty when the Telluride didn't, but that was actually pretty fun), but overall it drove and stopped very well. Turning wasn't as good, I think. It's obviously not an apples to apples comparison, but the Subaru had no problem handling the conditions and was very confidence inspiring...being a smaller vehicle made it easier to drive in some ways, but I'm also very familiar with it to begin with.
I would say the Telluride has a capable AWD system, and I'd put it better than the Sienna AWD that I recently had. I'm not sure how I would rate it compared to the Subaru.. I'm inclined to say the Subaru system is better, but I will have to drive both some more to get a more complete picture.
I will try to post some pictures / videos later.
Lots of snow + new AWD vehicle + snow tires = fun day.
