can the AC be turned on?
wendyd
upstate NY
using the remote start app on the phone can the AC be turned on come summer time?
Yes, set the temperature to something lower than ambient, ie 70 degrees when its 85 degrees outside, on the APP then start the vehicle.
Yep, of course! Just set the desired temp and the auto climate does what it needs to get to that desired temperature. Worth noting that I don’t believe you can set the rear temp from the app, but still much cooler than not at all!
