Fog lights on an EX
JonFar111
Wisconsin
I had an extra set of cheap DRL's in the garage, so today I decided to see what aftermarket lights might look like. Not bad, if I say so myself.
I haven't hooked 'em up because I'll most likely install some PIAA fogs that more mimic the SX.
Let us know what you end up ordering and how they look. I’m wanting to do this one mine but would have to pay someone as I’m not mechanically inclines in the slightest. Someone in a Facebook group added them as well and had them connected to the DRLs so theyre always running and no switch. Seems cleaner but I’m not sure I want them on all the time.
That’s the way my installer friend said was easiest. Then no messing with inside wiring or going thru the firewall.
From a distance, your high priced emblem looks like a big hole in the grille, like something fell out. But of course, it’s just my opinion. ⚫
I actually have a 50 cal mounted behind the grill. Helps with traffic control.
Actually depending on the light, you’re right. I did and still do feel like the black and chrome emblems look like a 100 other car brands... I may get tired of black on black and try something else another day. Just another $34 for another set of front and back emblems...
for $34 (not expensive) get other pattern for your emblems
(y)
I am also replacing my badges I order the same color I have right now but instead of plain white will be white carbon as backgroung
I took out the stock Sylvania 9005 headlights and installed Sylvania Silver Star 9005 headlights. The projector headlights were designed to work with halogen bulbs and I didn't want to mess with trying to fit a canbus into the small enclosure. I have attached a chart showing the difference. The bottom headlight picture is what is currently installed in the Telluride. the top picture is what I installed. BIG improvement and took 10 minutes.
Hi I just got a ex telluride not to long ago and I’m looking into where to buy a fog light kit? Could you guys give some sites or links to where you get the fog kits and the price. Thank you
What’s up everyone! I have a Telluride S and I got these installed yesterday. I went with the Nilight 40001F-B super slim fog lights. I’m happy with them and think they look pretty close to the ones on the SX. Here are a few pics.
If you don’t mind could go through the process of the install? I’m hoping it’s plug and play? Thanks
I see they are on independent of the headlights. Would like details of physical install and electrical hookup. Looks great. 👍🏼
Sweet! Three Q's. 1. Did YOU do the installation? 2. If "no" may I ask what you paid for installation. 3.Have you run them at night yet? I would love to see a photo showing how they illuminate the road. Thanks!
Sorry, but I didn't get any photos of the process, but here is a quick overview of the install:
Lights:
Nilight 40001F-B Bar Super Slim 2PCS 7Inch 30W Flood Driving Fog 3600LM Single Row Off Road led Lights for Jeep-2 Style Mounting Brackets, 2 Years Warranty
Wiring Harness:
Nilight LED Light Bar Wiring Harness Kit 12V On Off Switch Power Relay Blade Fuse for Off Road Lights LED Work Light,2 years Warranty
Shout out to one of my best friend that did the install. He does this for a living and hooked me up.
Physical install:
1. Remove the mounting screws on the front half of the under carriage protector/wind deflector. It will drop down and give you access to behind the front lower grill.
2. Cut the plastic insert in the lower corner of the grill. I cut the entire insert out cause the lights plus mounting hardware I got fit perfectly in there. I cut it out with a Dremel. The lights fit really snug in the ~1.75" opening.
3. My lights came with two sets of mounting hardware. One set for a flush mount and one set for a higher mount. I used the hardware for the higher mount and pointed them straight back towards the radiator. There are brackets that the bumper mounts on that the hardware can be attached to. We had to get creative on the drivers side and use of zip ties
Electrical hookup (my apologies for not knowing the technical terms):
1. Connected the black wire around the same bolt that the battery was grounded to the car frame (near the battery and fuse box)
2. Connected the red wire to a post in the fuse box. This post supplies power to the use box. We wanted to tap into one of the fuses and tried to use an "add a circuit" fuse connector, but it didn't fit. The "add a circuit uses mini-fuses and the fuses in the fuse box looked like mini-fuses, but the prongs were really close. The goal was to have it where the power is cut to the fog lights when the car is turned off. I have it wired so that there is constant power to the fog lights so I have to make sure I turn them off through the toggle switch inside the car. I didn't tap them into the head lights due to fear of voiding any warranty.
3. Connected the leads to the fog lights
4. Poked a small hole through the firewall and fed the toggle switch wire through.
5. Mounted the toggle switch just below the fuse box by the driver's foot because it was the easiest place to mount it. Most of the area around the fuse box has a metal plate behind the plastic. It turned out that I like it down there because the toggle switch is illuminated when the lights are on and it would've been really bright at night if it was higher up.
6. Zip tied and electrical taped everything so it is nice and neat.
The lights fit so tight in the lower part of the grill that you can't really adjust the aim of the beam. Good thing that are really low on the car that it does a good job of illuminating the ground in front of the car. I've driven a few nights so far and no one has flashed me yet!
1. I did not. My really good friend that does this for a living hooked me up.
2. Cost me a nice bottle of scotch🥃
3. Here are some pics at night:
headlights only
headlights and fog lights
fog lights only
