Whenever I start up my Telluride the rear AC turns on. I always turn it off via the touch screen controls and have "locked" the controls but it keeps turning back on. Anyone know how to keep it off until I manually turn it on?
Did the dealer diagnose the issue? I'm wondering because I have the same issue with my S AWD Telluride, and it's super annoying to have to turn off the rear climate control every single time I get in the car. I called Kia USA support, and they had no clue about the issue. They directed me to bring it to my local dealer, which I did when I picked up my plates, but they had no clue either and merely stated they would "let HQ know."Update: Turning the AC off from the rear ceiling control did not fix the issue. Dropping it off at the dealer on Monday so they can run a diagnostics check on the system.
Is this a 'problem' on all cars? Does anyone not have this problem of climate not staying synced? My back passenger is a baby and will not be controlling their own climate so I'd rather it stay synced to mine.
There are 2 problems. Some have their rear climate control always turning ON and other (as me) have them always turned OFF when starting the car.
Not for me. Have the car about a month nowDoes it work correctly for anyone? I will want to make sure I test it thoroughly when mine arrives.
So does your rear default 'off' each start? And you have to turn it on and re sync it?Not for me. Have the car about a month now
Yes exactly. I have a dealer appt this Friday so will see what they say but won’t take it if they tell me corporate has not figured out a solution yet. Buts annoying so I hope they have a workaroundSo does your rear default 'off' each start? And you have to turn it on and re sync it?
