Sportshot2
- May 5, 2019
Hi Stephen,
Please check
5XYP5DHC1MG125031
Thank you
Please check
5XYP5DHC1MG125031
Thank you
ETA showing 11-15 as of todayHi Stephen,
Please check
5XYP5DHC1MG125031
Thank you
Can not unfortunately only by Vin numberHi @StephenCantrelle do you have the ability to track a vehicle via order number? Just curious.
Thanks!
In transit to dealer... ETA showing 10-16 but likely will show today or tomorrow since going to SlidellHi @StephenCantrelle can you track 5XYP54HC1MG111453? Thanks so much!
Hi @StephenCantrelle, still 10/21? What status is it in and does it have WS attached? Thanks!ETA showing 10-21 as of today
Sorry not Port allocated or Transit Tending status........@StephenCantrelle can you please see if this bad boy is port allocated yet 5XYP5DHC7MG122652
Thank you!
Your name is attached.. ETA now showing 10-28 and is in VA status which is after the first step of being built so still some steps to go through before going In TransitHi @StephenCantrelle, still 10/21? What status is it in and does it have WS attached? Thanks!
@StephenCantrelle sorry in transit is the final stage? I'm sure you explain this on a regular basis so I apologize in advance if you have to repeat yourself.Sorry not Port allocated or Transit Tending status........
Because its already In Transit! ETA showing 10-26 as of this morning
Yes In transit is Telluride is physically on its way to the dealership.. last step before arriving@StephenCantrelle sorry in transit is the final stage? I'm sure you explain this on a regular basis so I apologize in advance if you have to repeat yourself.
Not showing on my end as In transit.. showing PA status which is a couple steps from In transit... showing ETA 11-02 as of today..@StephenCantrelle dealership says it’s in transit. Do you see that on your end? 5XYP3DHC3MG124002
It can go backwards in status? It was in TN status. Not sure why the dealership keeps saying it will be there on the 19th. Thank you for your help!Not showing on my end as In transit.. showing PA status which is a couple steps from In transit... showing ETA 11-02 as of today..
I have seen it happen before.. only thing I can think of when I see this is maybe they caught something on the car that is wrong.. Like a scratch in paint for example... and they take it back a step..It can go backwards in status? It was in TN status. Not sure why the dealership keeps saying it will be there on the 19th. Thank you for your help!
Thank you! Can you check this vin wondering if they are trying to switch me to the exact same car but with tow. 5XYP3DHC8MG127722I have seen it happen before.. only thing I can think of when I see this is maybe they caught something on the car that is wrong.. Like a scratch in paint for example... and they take it back a step..
I have one right now I am waiting on... her ETA was 10-06 and was in TN status... went backwards in status and now she is finally back in TN status as her ETA is now 10-20
Showing TN status ETA 11-01Thank you! Can you check this vin wondering if they are trying to switch me to the exact same car but with tow. 5XYP3DHC8MG127722
ETA showing 11-15 as of today.. Your name is attached@StephenCantrelle Could you track 5XYP3DHCXMG129441? Initials DW. Thank you very much
