- Mar 7, 2019
Name is attachedHi @StephenCantrelle , I forgot to ask you to see if my name is attached, initials J.C. Is it? 5XYP5DHC1MG139589 Thank you.
Thanks Steve. Just sent you a tip.In Transit to dealer ETA showing 12-08 as of today
Thank you!Thanks Steve. Just sent you a tip.
Thank you Stephen! Appreciate it.ETA showing 12-20 as of today
Thank you Stephen! I appreciate it. Might check back in a couple weeks to recheck status if that’s ok.ETA showing 12-20 as of today
not a problem.. Have a great weekThank you Stephen! I appreciate it. Might check back in a couple weeks to recheck status if that’s ok.
Yes still showing same.. In Transit to dealer with ETA of 11-29 as of today@StephenCantrelle Is the ETA on this one still 11/29? 5XYP34HC9MG133755 Thank you for your help!
Hey Stephen. Got an email from my sales manager that the delivery was moved up to 12/9/20. Any chance you can confirm and initial JN assigned to vehicle?In transit to dealer! ETA showing 12-17 as of today
Don't see a name attached which means dealer most likely hasn't put name if you put deposit on an incoming unit... ETA showing 12-17 on my endHey Stephen. Got an email from my sales manager that the delivery was moved up to 12/9/20. Any chance you can confirm and initial JN assigned to vehicle?
Thank you!Name is attached![]()
ThanksDon't see a name attached which means dealer most likely hasn't put name if you put deposit on an incoming unit... ETA showing 12-17 on my end
Name is attached... In Transit to dealer ETA showing 11-29Hi @StephenCantrelle , can you check on 5XYP5DHCXMG136187 and if it has initials PA on it? Thanks!
In transit to dealer! ETA showing 11-27 as of todayHi @StephenCantrelle, can you check on 5XYP3DHC5MG139410. Just seeing what the ETA is and if it's been loaded on a truck yet. Thanks so much
In Transit to dealer ETA showing 12-07 as of todayHi @StephenCantrelle curious if my Telluride is still holding its date? 5XYP6DHC6MG135616 just set up a Venmo too, I appreciate it!
Thank you! Hope you got the tip!In Transit to dealer ETA showing 12-07 as of today
Thank you very muchIn transit to dealer! ETA showing 11-27 as of today
