Moving this into the lighting section.I recently purchased a KIA 2021 Telluride SX. Can the LED High Beams be adjusted without affecting the regular beams? The high beams really do not light up a dark the road ahead very well.
Lots of talk if you use the search toolI recently purchased a KIA 2021 Telluride SX. Can the LED High Beams be adjusted without affecting the regular beams? The high beams really do not light up a dark the road ahead very well.
No, since these are not separate lamps, but when turned on, additional diodes are turned on.I recently purchased a KIA 2021 Telluride SX. Can the LED High Beams be adjusted without affecting the regular beams? The high beams really do not light up a dark the road ahead very well.
First things first - The assembly is different from the bulb. The bulb could still work with a damaged assembly. And adjusting has nothing to do with a bulb being out so I'm not sure what you are asking/stating.The bright lights on my 2020 EX quit working. Took it to dealer and they looked at it, noticed small dent in bottom of bumper assembly and then refused to do anything further and suggested I contact a body shop. Looks like somebody backed into my car in a parking lot because there has been no accident or collision of any sort. Service writer who had little knowledge of the assembly had no idea how I could look at it to adjust it and mechanic refused to talk with me. Friend has a 2020 S and added LED lights and they are wonderful but if the assembly itself isn't operational I don't see the use in changing to LED. Any info on how to check the bright light adjustment assembly?
Brights quit working at the same time. Don't know why or how I go about checking to see if the mechanism has been damaged or has an inherent problemFirst things first - The assembly is different from the bulb. The bulb could still work with a damaged assembly. And adjusting has nothing to do with a bulb being out so I'm not sure what you are asking/stating.
Now, one or both bulbs?
If both, same time or different times of failure?
If you can be as specific as possible, people will be able to answer you question.
First question - you checked the fuse, right?Brights quit working at the same time. Don't know why or how I go about checking to see if the mechanism has been damaged or has an inherent problem
Yes. Even tried the spare 15 amp & no difference. What I've read so far suggests this is a mechanical function & I'm hoping someone has info on that. Thanks!First question - you checked the fuse, right?
Fuse Box Diagram Kia Telluride (2020-2023)
Fuse box diagram (location and assignment of electrical fuses and relays) for Kia Telluride (2020, 2021, 2022, 2023).fuse-box.info
What is the function of the hi-beam relay? Could it be the problem?Yes. Even tried the spare 15 amp & no difference. What I've read so far suggests this is a mechanical function & I'm hoping someone has info on that. Thanks!
