Rear Bumper Protector and Aluminum Skid plate.
Tellyride365
Does anyone have pictures of what either one of the Rear Bumper Protector and Aluminum Skid plate look like?
There are only stock "KIA" pictures in place of real ones when you select these in the build page.
If anyone has these on theirs please post a picture of either one. Thanks!
I bought the Rear Bumper Protector and installed it myself. Cost $100 It has 3m tape on the back side. Comes with instrucrions to install.
Very easy to install. Clean bumper with rubbing alcohol, there is a little arrow in center of protector you line up with latch. Dry fit and Use masking tape to mark each end. Peel off backing tape and apply. They suggest not get wet for 24 hours. Has very good instructions. Ps it covered the area I already damaged my bumper cover pulling a slide out of the back!
Do not wash car for 48 hours
where do you get these? Thanks
You can get from your dealers parts dept or look an order online. I have attached a screen shot of an online location - there are more - the screen shot has the part number so you can research for best price.AB52FAFF-CDFF-43B4-AD69-BB27BE0D8211.webp
You can get from your dealers parts dept or look an order online. I have attached a screen shot of an online location - there are more - the screen shot has the part number so you can research for best price.View attachment 2239
Thank You appreciate it!
Dealer or on line. Ask you dealer fo a discount. Show them the on line price. My dealer had 2 in stock. $80 plus tax
Is this the same as the "Rear bumper applique" on the Kia Website build configurator? It's $120 if ordered from the factory.
What website is that on, been looking can't find site
What website was it purchase from can't find them Thanks
Where did u buy them from
That says black I want the aluminum ones
A skid plate typically refers to a protective plate that is installed on the underside of the vehicle. I haven't seen one on a Telluride yet. But the black bumper cover can be seen in Lou's post above from July, 4, 2019. The aluminum protective pieces in the cargo area are not the "skid plates" I believe you are referring to. Not sure what KIA is calling those two aluminum pieces, but are they not installed on every trim level?
That's what I'm looking for the aluminum pieces on the cargo area
OK, that's what I figured you were looking for. Not sure where to find them. Which trims don't have the aluminum pieces in the cargo area, and what type of pieces are there if not metal? Just curious. Thanks.
I have the S model and it has the black plastic
