lydiav
Since about 8350 miles (now at almost 10k) I have been having an intermittent issue with the error "Front Avoidance Assist (FCA) system disabled, radar blocked". There is no rhyme or reason when it will occur and it does it every time I drive regardless of weather and highway vs city driving. If I have cruise enabled and it happens it shuts down and disables cruise control too.
I find it clear itself and then will disable again, repeat. If I stop, turn off the car and restart it will also clear. I have taken it to the dealer and they are having issues reproducing it. I have the following photo showing the error when it first happened. I have inspected the sensors to make sure nothing is actually blocking. Have seen same error appearing on the Stinger (other forums) so seems it may be just a wiring issue and hopefully not a wide spread problem.
Will update when I get some suggested resolution from dealer. BTW I have EX AWD and extended warranty. I have been driving almost exclusively in ECO mode.
