2020 with key fob remote start and 7 pin hitch?
dlarson88
Is it known yet if we can upgrade 2020’s to the key fob remote start and 7 pin town hitch that will be coming on the 2021’s?
All of those things can be added aftermarket today. For remote start options, check out that thread and a recent post. For 7-pin, you can see parts on etrailer and there are lots of posts here.
Hopefully the 7-pin harness will be mostly plug n play and higher powered than the 4-pin harness. The current 4-pin option is rated for less load than the less expensive aftermarket options. Trailer wiring - running lights don't work
The key fob remote start option is a different story. Given the cost of two new key fobs and proximity programming them with your vehicle, I can’t imagine that putting the 2021 remote starter control module option on a 2020 Telluride AND swapping the fobs is going to be cost effective. So hopefully the option will be plug n play and work with reprogramming a single button double or triple press to start the Telluride and cost the same or less than some of the current aftermarket options that do the same thing.
