I bought a Kia Telluride EX, the navigation system worked fine up until March of 2020, I’ve contacted the dealership as they were no help, I called Kia customer service several times with not much help, they said they would send a SD card for it but couldn’t tell me where I had to put the SD card, I’ve searched that car high and low and can not find a slot for a SD. Anytime I try and search a new address, it says location not found weak signal or offline! If I use a previous destination it works with no problems! Anyone else have this issue?
Yeah, it doesn't work that well. It's not a Mercedes. But, there is a software update they may apply posted in the TSB section of forum. I need to do that update. And then there is the Mapnsoft update which should be available soon for purchase. Also, for voice, I think you need an active UVO subscription. Did your UVO expire?
If you want voice recognition, you'll likely be much better served with Apple CarPlay or Android Auto.
