Rear Turn Signal to LED
Yes they are bright.... But when the brakes are applied the lower part of the light gets brighter.
Thanks. I tried a similar bulb with the same results, not to mention that the heat created by the ones I 'tried' was concerning. There has to be a happy medium for a lower wattage LED running and/or combination running/brake light. I'll do some more research. Thanks again for your input!
View attachment 7248 Halogen on the left... LED on the right. Believe me... The LED’s make a difference!
How did you change them out ? Is it just that cover off to the side of the assembly that needs to pop out & gives you access to the screws. Also I see most come in packs of two, did you replace the top third brake light too ?
Thanks !
The protective plastic panel on both sides pops off with light pressure from a screwdriver. That will give you access to the three screws that hold the light assembly onto the frame. Once that is unscrewed, it's easy peezy to change all the bulbs. You will need (3) sets of two or a total of six bulbs if you plan on changing all of them out.
Did you replace the third brake light up top or no ?
If I understand correctly, the 2 5w5 are for the reverse & the 2 P21/5w are for the brake / running lights correct ?
Thanks again,
Thanks again,
These are the ones I have. The 1797 red are for the brake/running lights and the 912/921 are for the reverse lights. Haven’t had any problems with them up to this point.
What is the number of led lamps that will be put in place of the turn signals (telluride for canada)?
What lamps to replace the standard 26W 8 LL?
