SARTING ISSUE
hi brothers ..thanks for all ..finally i found the problem is because of bad battery only ....
I am glad to hear it was all fixed. Thanks for letting us know. Happy Driving!
Boom! And @Senator20 for the win! I guess @tpgh owes you an apology now. Talk about spitballing! That fuel issue was a good guess though! "It’s clearly not a battery issue" 🤣
Again, if you watched the video with sound, you could hear the starter turning over. If it was the battery, the cranking of the starter would progressively get slower and then not crank at all. An engine operates by simple principles. Engines need air (oxygen) to burn fuel. The fuel is ignited by the spark plug, or in a diesel, compression. His vehicle is trying to start but doesn’t fire. Most likely fuel is not getting sprayed into the cylinders by the injectors. It could also be an electrical issue resulting in the spark plug not arcing. But one thing it clearly isn’t, is a battery issue.
It was a battery issue.
