Spewing fluid
LA Poovey
Since buying my 2024 Telluride in Aug. 2024, I have fluid spewing from under the hood onto the windshield. Had the car checked and was told it was tree sap. My car spend 20 hours a day in a garage, door closed. When I am out, it is parked on asphalt payment parking lot with no trees. Tree sap does not spew from under the hood. i have researched the issue and found it could be problems with the coolant system or the washer fluid system. The dealership supposedly check for leaks, damaged hoses, etc. and found no problems. Has anyone else dealt with this and if so found a solution?
