tazzytazzy
- Aug 24, 2020
Hello. Can I ask you a question as I am totally new to towing and just got my 2021 Telluride with tow package, about a month ago. So mine comes standard with a 7 pin hitch. I am looking at purchasing a Winnebago 2106DS Friday. The dealer is asking me what type of receiver I have, where I have a harness for connecting, and what the tongue weight is. He's telling me I'll need trailer brakes for $1,000. I was under the impression that I could buy a hitch (Another $1,000), and simply plug one into the other and go. Can I have you tell me how you set yours up? Thanks, Scott
Since this is your first time, take it slow. Drive slow. Give plenty of room ahead of you. Look far ahead to look for breaking and possibly coasting to save gas and having stop/start as much. Sometimes driving 5mph slower than traffic when coming to a red light may avoid you having to come to a complete stop. The good thing with the tandem axle, you'll get less trailer sway. This also means, you won't notice a flat tire on the trailer and this will lead to fires! Be sure to replace the newly provided tires within 1-2k miles if they are made in China. These tires explode or fail within 5-10k miles and have gained the nick name of "China bombs" (I hated typing that). Also, use a TPM for the trailer. Yes, they are extra $$$, but it's cheaper than your deductible and all the stuff inside. See: trailer tire fire at DuckDuckGo
We just spent the last 2 months looking at trailers and shopping. So not fun with nearly no stock anywhere and high prices. I suggest you look at 2019 or 2018 NADA guide to help you pricing your 2020. I hope you're not settling for a trailer as it does weigh pretty high for the Telluride, I'd suggest getting a smaller one without a slide to save a couple hundred pounds. The average dry weight on MFR specs are typically low.
The dry weight on the tongue is 360 for your trailer. A single battery will add 50-60 pounds and the 2 propane tanks will also add lots of weight. You also have to include your hitch, which can add 50-80 pounds. After your food, camp gear, clothes, water, waste water, etc, you'll easily get over 5000 pounds. The 2106DS can store 31 gallons of water, which when full, weights 264 pounds, leaving 300 or 400 pounds for people, clothes, food, and gear. Hope it's only one or 2 of you as bring a 3rd or 4th will put you over weight. You'll for sure want to keep weight to a minimum for your gear, for example use melamine dinnerware and plastic flatware.
The Mini Micro's are nice and are rated pretty good for build quality from what I've read. We wanted a Venture RV Sonic 199VRB. Has everything wanted: large fridge, oven, tandem, 3600 pound dry. But, they dealer is gouging around here and Venture RV doesn't require their dealers to honor their warranty. So, no buying elsewhere and bringing it to the local shop - they already told me they won't service it; Yelp reviews confirm that.
We just ordered a Kodiak Cub 177RB. It's small, the only thing we don't like is the lack of an oven. However, it's lighter weight and less maintenance due to no slide. Yes, most dealers will say they are much better than yester-years, but they still fail. Not removing fallen leaves before retracting slide is very bad for everything. We did find one dealer that said "yes, anything with a motor, gears, electrical, and seals can eventually fail which the slide has all those". We will be taking delivery hopefully in early to mid Feb. The great thing about this little trailer: it holds 52 gallons of fresh water, more than any other trailer we've seen. We plan to fill up only at the campground because 500+ pounds of water adds up.
I've started a couple Amazon shopping lists, I'll share it here:
Check out my list on Amazon
www.amazon.com
On there is a BlueOx WDH: https://www.amazon.com/dp/B001DMFO6...olid=2XD6EIT7S8DB8&psc=1&ref_=lv_vv_lig_dp_it
This hitch is good for trailers between 350-550 tongue weight. It also has the benefit of no grease for the sway bars, and you can backup the trailer with the sway bars still attached. It also doesn't weigh too much. A note about the WDH. It does transfer some of the weight to the front wheels, but you still cannot exceed the 500#'s total tongue weight, including hitch.
We don't get anything from you buying anything from the links above. Just my research on things to buy for the trailer.
Good luck and pack very light as you'll only have 100-200# total available cargo weight after 2 adults, batteries, propane, and WDH. :\ This doesn't leave much for camping hear, clothing, or food.
