• Need to track your Telluride? Don't start a new post in the lounge - CLICK HERE!
Just bought a 2021 Telluride EX with hitch package...does it come with all necessary pre-wiring to haul small trailer or airstream?
Jimbob
Just bought a 2021 EX Telluride with hitch package...does it come with all necessary pre-wiring to haul small trailer or airstream?
As I understand it - yes, if the camper doesn't have electric brakes. If you need electric brakes, the basic wiring is there and they give you an extra cable harness for wiring up a brake controller, but you would need to buy a brake controller and install it - but the 7-pin plug is there to accomodate the brake controller.
Sorry to keep rehashing the towing questions, so the 21 only difference is that it is just a different adapter and no brake system? I know they advertised this as an improvement over the 20 but I can go to Walmart and buy a 4 pin to 7 pin adapter for $15. Seems a bit unsafe to the less knowing that are going to tow and think its providing what they need judging from the initial post on this thread.
Welcome aboard! And thank you for signing up. Congratulations on your brand new Telluride! What did the Telluride replace for you? I'm glad you found us. :)
Okay thanks 😊
CRV....I’ve had eight Hondas and three CRVs....hopefully the telluride will be as reliable and issues-free as the Honda...
I dont have a hitch on my 2021 telluride s, however I plan to install one. In the specs on the lower lx model it says 7pin trailer wiring harness as a standard item. The S model has everything the lx has plus more. Does it mean the vehicle is prewired so it is capable even those without a hitch?
The 2021 with factory tow package has a 7-pin connector in the back.. if your towing a large trailer with electric brakes you'll need a brake controller added. The 7-pin harness in the back doesn't do much move than a 4-pin will do by itself...
The 2021 has a molex connector underneath the dash that will allow relatively easy connection to a brake controller that will be hard wired to the 7-pin in the back. 2020 models do not have this extra wiring from under dash to rear trailer harness
Ah ha! That's good to know. I have a 2021 and may eventually want to put a brake controller in (depending on what Camper Trailer we end up getting). It's good to know there is pre-wiring there to make the task easier.
I believe just the hitch alone is an option too. Be sure to get the tow package.
My understanding is only EX and SX offer tow package option. For other trim, the kia telluride hitch kit (AA023) need to be ordered and installed. Neither option includes a brake controller.
