I am really mad mine used to display song and artist and now it does not.No idea. I didn't do anything special to get that to display.
I’m not near my vehicle right now, but I think you can hit that hamburger button at the top left by the home button and then choose info from that drop down menu.I am really mad mine used to display song and artist and now it does not.
I agree 1000%.I am really mad mine used to display song and artist and now it does not.
When you say you transferred the folder to your portable hard drive, do you mean you transferred the folder or just the contents of the folder?
The car is looking for the update files to all be at the top level, not nested within another folder.
Just double checking because if so, that may be your problem.
Bruesjoh04 and TheNip73.....bam!!! That worked. Thank you both for something I should have caught.Yes - do not copy the folder, only the contents inside.
Cool - something for me to test out after my kid is in bed.I’m not near my vehicle right now, but I think you can hit that hamburger button at the top left by the home button and then choose info from that drop down menu.
I never listen to radio, so the only time I ever pull this up is to look for changes. I’m pretty sure that’s something I saw.
You are right - need to enable the info checkbox! Why is this not the default setting!I’m not near my vehicle right now, but I think you can hit that hamburger button at the top left by the home button and then choose info from that drop down menu.
Bummer. Was hoping they had OTA updates. Is it pretty easy to do?You go to update.kia.com and follow the directions.
You’ll need a USB stick and a Mac or a PC to download the update. You’ll then use that to install on your vehicle.
Download an installer, put the files on a usb stick, plug usb stick into car, push on a few prompts, wait 45 minutes for process to complete, done.Bummer. Was hoping they had OTA updates. Is it pretty easy to do?
I have a 2021 SXP that I took possession of a few weeks ago. It didn't have the November update. Do I have to do that November update first? Doesn't look like it's available on the website through the updater.Already done. If you did the 14.10 update from November, you’re not really going to notice any differences.
15.0 is a map update along with some very minor changes otherwise.
No interface changes, no design changes or customizable options, no widescreen Android Auto.
No, and at this point, you couldn’t download the November (14.10) update if you wanted to since it’s no longer available. You just load a USB stick with the most current update and it will take care of the rest.I have a 2021 SXP that I took possession of a few weeks ago. It didn't have the November update. Do I have to do that November update first? Doesn't look like it's available on the website through the updater.
Well, no complaints should be had here. I haven't had it long enough to get used to anythingNo, and at this point, you couldn’t download the November (14.10) update if you wanted to since it’s no longer available. You just load a USB stick with the most current update and it will take care of the rest.
Just make sure you do your homework and decide you’re fine with the interface changes (most noticeable if you usually are using the main home screen) before you do the update. I don’t want to hear any more complaining from people who don’t research things and then are surprised something they like is gone.
Setup > Nav > display > information > unitsOK - I did the update today but the damn thing reset everything. The HUD is now showing in KPH vs MPH. How do I change it to display MPH again?
I lost my Speed Limit Road Sign on my HUD after I did the update yesterday.OK - I did the update today but the damn thing reset everything. The HUD is now showing in KPH vs MPH. How do I change it to display MPH again?
Thanks - I checked the settings via the steering wheel first but nothing showed up thereSetup > Nav > display > information > units
Whoa. Does that work for Sirius XM? I haven’t listened to FM in over 10 yearsYou are right - need to enable the info checkbox! Why is this not the default setting!
Now I get song info and what appears to be an album cover
The newest available update (15.0) is primarily a map-only update if you are updating from the prior version (14.10).I just found this thread, read most of the comments, but did not see anything that addresses my question. So, here goes. I have a 2021 EX that was delivered in mid-November. My infotainment format is the tri-screen (map, media, weather) display. I have not loaded any updates since. If I was to load the latest update that was released in mid-April (some have referred to it as primarily a navigation update), what will happen to my current format? Will I lose the tri-screens?
Btw, even though this system has been described as intuitive, I have had a particularly tough time absorbing all these features. Not sure why, but, I have been frustrated at times when trying to customize various settings.
Thanks for reading.
