MS and or CSWhat is your initials and I can confirm for you.
If you wouldn’t mind checking just want to make sure still on target for 4/22Thank you!
MS is attached! ETA showing 04-30 as of todayMS and or CS
Showing In Transit... ETA 04-22 as of todayIf you wouldn’t mind checking just want to make sure still on target for 4/22
5XYP3DHC4MG170485
Thank you
Hi Stephen. Would you mind checking status again for me, please?Your name is attached... ETA showing 05-16 as of today
Oh man. Sometimes it feels like it’s never going to get here.ETA showing 05-07 as of today
Showing In Transit to dealer ETA is 04-22 as of todayYou were correct last time, dealer had given me the incorrect vin! They called to confirm about a couple weeks ago. Could you check eta on 5XYP5DHC7MG173892? Thanks again!
ETA showing 05-24 as of todayHi Stephen. Would you mind checking status again for me, please?
Thanks!
That's normal if it isn't a custom order and you simply put deposit on one already assigned.. This is showing In Transit with ETA of 05-06 as of today.Hi! Can you track 5XYP5DHC4MG174031 for me? You had previously said no initials are attached but dealer says the car is for me. Does that sound suspicious to you for any reason?
Showing same status as of today.. In Transit with ETA of 04-28 as of todayHi Stephen, can you please check the status on 5XYP5DHC4MG174675? Thank you!! Hoping to see it come in this week.
Your name is attached.. Showing In Transit to dealer with ETA of 05-08 as of today@StephenCantrelle ...would you be so kind to check on VIN 5XYP3DHC2MG178388. SM should be attached...Thanks!
It was a custom order for me. I didn’t put down a deposit on one already assigned. That seems weird, then?That's normal if it isn't a custom order and you simply put deposit on one already assigned.. This is showing In Transit with ETA of 05-06 as of today.
Then it is possible dealer had exact match coming in before your order and opted to move you up to this one. To get soonerIt was a custom order for me. I didn’t put down a deposit on one already assigned. That seems weird, then?
Are there any initials associated? RC? RH? RK?Then it is possible dealer had exact match coming in before your order and opted to move you up to this one. To get sooner
I see full names and I don't see anything attached.. Guess it could be a one time thing where I can't see. Does it match your order?Are there any initials associated? RC? RH? RK?
Yes it does match my order. And he has verified vin. I guess I shouldn’t worry!I see full names and I don't see anything attached.. Guess it could be a one time thing where I can't see. Does it match your order?
