Track my vehicle
If you wouldn’t mind checking just want to make sure still on target for 4/22
5XYP3DHC4MG170485
Thank you
Showing In Transit... ETA 04-22 as of today
You were correct last time, dealer had given me the incorrect vin! They called to confirm about a couple weeks ago. Could you check eta on 5XYP5DHC7MG173892? Thanks again!
Showing In Transit to dealer ETA is 04-22 as of today
Hi! Can you track 5XYP5DHC4MG174031 for me? You had previously said no initials are attached but dealer says the car is for me. Does that sound suspicious to you for any reason?
Hi Stephen, can you please check the status on 5XYP5DHC4MG174675? Thank you!! Hoping to see it come in this week.
@StephenCantrelle ...would you be so kind to check on VIN 5XYP3DHC2MG178388. SM should be attached...Thanks!
That's normal if it isn't a custom order and you simply put deposit on one already assigned.. This is showing In Transit with ETA of 05-06 as of today.
Showing same status as of today.. In Transit with ETA of 04-28 as of today
It was a custom order for me. I didn’t put down a deposit on one already assigned. That seems weird, then?
Then it is possible dealer had exact match coming in before your order and opted to move you up to this one. To get sooner
Are there any initials associated? RC? RH? RK?
I see full names and I don't see anything attached.. Guess it could be a one time thing where I can't see. Does it match your order?
