I'll try to answer for you. Part 1 - it's probably close to 100% that the initial date will move. That can be as little as 1 day either way all the way up to weeks later. The failcat thread answers your second question. You should read it. But, the answer is that failcat is updated when the VIN is created and the VIN is created during the build process. Thus, when it shows up in failcat, it can not be in transit (although there are exceptions noted in the failcat thread) unless your are looking at data that is old.Stephen how possible is it for these ETAs to change to earlier or later? And is everything on failcat “in transit”?
Winner Winner... has your name attached. ETA showing 06-22 as of todayHi @StephenCantrelle I think my deli baloney sandwich is done, could you check if that sandwich is mine and an ETA please? 5XYP5DHC9MG190239 Initials, R.B.
Thanks for the infoI'll try to answer for you. Part 1 - it's probably close to 100% that the initial date will move. That can be as little as 1 day either way all the way up to weeks later. The failcat thread answers your second question. You should read it. But, the answer is that failcat is updated when the VIN is created and the VIN is created during the build process. Thus, when it shows up in failcat, it can not be in transit (although there are exceptions noted in the failcat thread) unless your are looking at data that is old.
Thank youIt shows up in the website when they "Invoice to dealer" basically when they are about to ship out from plant. Time will differentiate by distance from factory to dealer.. can be days to weeks.
In Transit to dealer with ETA of 05-29 as of todayHi @StephenCantrelle would you mind checking on 5XYP5DHC1MG184693 again?
Your name is attached. ETA showing 06-19 as of today...Hello @StephenCantrelle can you check the eta for vin: 5XYP5DHC8MG188224 initials JL? Thank you, sending some moolah your way!
Sweet!! Thanks again.Your name is attached. ETA showing 06-19 as of today...
Thank you!
I can not see anything from other dealers until Vin is assigned.Hi - I ordered from Doug Smith Kia in Sept, have been told I’m number 4 on their list but see numerous cars on failcat everyday under this deal and none are my car. Are you able to see if my order is in? It’s a Wolf gray SX with prestige, cross bars, towing, most of the options.
Oh I see- when my order does get into KFOS, how long is it usually til you get it, and when are they starting 2022 production?I can not see anything from other dealers until Vin is assigned.
If you are number 4 on the list that means you are still waiting for your order to be accepted in KFOS. So at this point will be getting a 2022
On average 2-3 months.. no news on 22 production start up dates yetOh I see- when my order does get into KFOS, how long is it usually til you get it, and when are they starting 2022 production?
