Wiper problem
FireballUS10149
My 2021 telluride SX has an issue with intermittent wiper setting. If I turn it on, the wipers only swipe about once a minute. I have it on the fastest setting but doesn’t swipe enough to work effectively. My other car has a “smart” sensor that controls swiping based on the amount of rain. Does anyone else have or has anyone else had this problem?
I was just mentioning to the wife the other day how confusing the intermittent wiper settings were. The bottom, smallest bar seems like it would be the fastest setting but it's the big fat bar at the top. Perhaps that is your issue.
Thanks but not my issue. Doesn’t matter which wiper setting I use on intermittent.
Ah, time for a trip to the dealer
Some owners have found the rain sensor, circle lens behind the rearview mirror, has either been installed improperly against the glass or was not properly wired from the factory. They required a trip to the dealer to correct.
An easy way to tell if the rain sensor works at all is by spraying water from a hose directly at the sensor on the window.
