 - Mar 7, 2019
ETA showing 07-22 as of today@StephenCantrelle If its not to much trouble can you look up the following? 5XYP6DHC9NG200282 Should be heading to Western NY. Thanks for the forum help!
Will get you Monday morning brotherHey Stephen, thanks so much for keeping us all in the loop. I can’t believe it’s my turn!
Initials TH or PH.
5XYP5DHCXNG203064
Starbucks $$ coming your way
Thank you very much!RH is attached and showing ETA of 07-10 as of today
Hey Stephen, when you get a moment, could you check VIN 5XYP6DHC9NG198243 again? Appreciate all you do siir.Your name is attached.. showing In Transit to dealer with ETA of 07-02 as of today
I’d recommend redacting some of your personal info. Just use your phone to edit it.Hi @StephenCantrelle , My dealer said my order was submitted to kia (I originally placed the order back in January) . Attached is what they sent me as a confirmation. Is there any way for you to check the attached and let me know if it has been submitted to KIA KFOS. Thank you!
Thank you Butch! I forgot to do that, it's now fixed. I was told the order had been placed when asked if we recieved an allocationI’d recommend redacting some of your personal info. Just use your phone to edit it.
Stephen will have to jump in, according to the Request ID this was submitted it in June. Not necessarily to Kia, but that’s when it went into the dealers local system. I’m thinking you got a new request ID when they transitioned the orders to 2022 models… hopefully.
Did your dealer let you know what your position was in line?
In failcat, select all cars then click on the word "created". It will sort in reverse order and then you will get your answer.On failcat, the total number of vehicles, does anybody know what time frame that started? Fiscal year?
If you had looked at the time between your last post and this one, you would have seen that he has answered no one. Patience is a virtue......Hey Stephen think my comment may have gotten lost! Could you check eta on vin 5XYP5DHC5NG203053
Initials should Be under MCO, MO or CO
thanks!
I couldn’t find mine… I thought maybe I forgot to submit it. Just went back and found it… no reason to be rude!If you had looked at the time between your last post and this one, you would have seen that he has answered no one. Patience is a virtue......
