Heated seats
armygirly68
I have a question about the heated seats. Typically, it will reduce from full three bars/high to two bars/medium in about 20 minutes. Yesterday, it started doing that after 10 minutes. I searched here and didn’t find an answer. A previous poster had a video showing how to adjust using the screen. However, my setup doesn’t have a “vehicle” button to select. I did see that it might have to do with the vehicle/outside temperature so I fooled around with the AC/heat but it did not make a difference. Does anyone know how to adjust it and where the control would be?
Thank You so much!
It’s supposed to automatically decrease heat level to prevent burns. If you manually turn on the seat warmers, it decreases from high setting after 30 min and from medium after 60 min.
If you have an AWD SX, your seat warmers may turn on automatically with the climate controls, which can be configured on/off in your head unit settings. I think when they are automatically controlled, they will adjust based on the cabin temp, and may turn off faster depending on how quick the set cabin temp is reached.
19C81FD8-A4C9-4CBA-9D2F-14BDFFBCFBA3.webpD175C201-3802-4759-86EA-2F3DA9550797.webp79B8BAE4-0E72-414B-9B07-C6AF562FADF3.webp
View attachment 22884View attachment 22885View attachment 22886
Very informative!! Thank u sir!!
