Not sure. Was this an answer to my above question?tagged
Mmm if it’s what I am thinking. You need to pry the plastic black cap off and the actual screw will be under the plastic black cap. I will double check after dinner and confirm this for you unless someone else chimes in before I do.Another question:
In the initial step where you are supposed to move remove the hood release handle with a socket wrench: I used everything from 6-10mm and none of them fit over that little plastic piece effectively to remove it. How does that little plastic piece come out of the hood release handle? There are 4 little plastic parts in a circular pattern. Does it turn to get removed? Do they have to get squeezed together to remove the handle? I dont want to break the plastic trying to get the handle off.
No this is so I can follow the thread for laterNot sure. Was this an answer to my above question?
I did the same thing as you with the sockets and it didn’t work. I finally just used a screwdriver and pried it off. It didn’t take much force to do itAnother question:
pried off the handle itself with a screwdriver or pried off that little plastic round bolt piece in the divet within the handle?I did the same thing as you with the sockets and it didn’t work. I finally just used a screwdriver and pried it off. It didn’t take much force to do it
Thank you for the explanation about the wires.@JasonWolf
No wires are to be removed from the stock connectors...
The wires are to be tapped into only.
The wires are to maintain their original connections to maintain their basic function - the tapping into of the module wires modifies to add the proximity function.
In my case, didn't use the hood switch...
Pried off the handle itselfpried off the handle itself with a screwdriver or pried off that little plastic round bolt piece in the divet within the handle?
I believe I was confused on what you're talking about...What do you mean you didn't use the hood switch? Are you saying you completed the installation of the module without removing the hood release handle?
It is intended to be popped off. Nothing actually screws it downWhen the handle came off, what did that little bolt look like? How is it attached to that inner part? Does it just pop off or is it intended to be screwed off?
They said the posi-tap connectors can come off.
