rear entertainment tvs
Pmkn1
does anyone know how to set the rear tvs so that they dont light up everytime the vehicle is turned on? they are so bright and we do not use them.
Is there a fuse you could pull that wouldn't affect anything else? These systems sound like a real afterthought and a PITA.
I've asked the same question. I downloaded the KIA RSE manual and could not find the answer. I just ended up unplugging the cable from the rear and that solved that problem.
Where is the cable located exactly? Same issue. I don’t want to drain the battery. Thank you
