ucinn
Driveshaft would make it go away with a gear change and it doesn't, so probably not the driveshaft... Wheel bearing, CV joint, long shot would be a rotor. Tire or wheel.
Three questions, please:
1) What magic words do we say to the service department to have them look into this - just "CV Joints hitting harmonic distortion?"
2) What kind of tests do they do to verify the problem?
3) What do they do to fix the problem?
CV Joints are the connection points (rods and joints) that go between the transmission and the front wheels. Many many front wheel driven cars have CV joints and when they tend to go bad, most people complain of a vibration. I'm not saying that they are going bad in the new telluride, but they are not balanced thus causing the vibration. I've seen it and felt it before, so that is my first suggestion.
While not my profession, I do wrench on cars a lot.
Wouldn’t this also include FWD vehicles? Seems to be AWD only so far...CV Joints are the connection points (rods and joints) that go between the transmission and the front wheels. Many many front wheel driven cars have CV joints and when they tend to go bad, most people complain of a vibration. I'm not saying that they are going bad in the new telluride, but they are not balanced thus causing the vibration. I've seen it and felt it before, so that is my first suggestion.
Maybe - Maybe Not.Wouldn’t this also include FWD vehicles? Seems to be AWD only so far...
Maybe - Maybe Not.
While the transmission is the same for both, the AWD has a transfer case and the FWD does not. So the parts for the CV Joints are likely different between the AWD and the FWD to accommodate the addition of the transfer case.
A lot more moving parts. Transfer case, drive shafts, rear differential and CV jointsWouldn’t this also include FWD vehicles? Seems to be AWD only so far...
Question for you Albert,A lot more moving parts. Transfer case, drive shafts, rear differential and CV joints
No. I haven’t tried it in other modes. I’m hoping when I get it back the issue would have been resolved. But if not... I guess I’ll give that a try.Question for you Albert,
You mentioned earlier that you felt this in comfort mode. Have you felt it in other modes? The reason for the ask is that the settings transfer more of the drive to the rear wheels than other settings. I was wondering if it was transferring power to the rear wheels and as such, putting the drive shaft under load.
(I would try this myself, but our black copper is in the body shop - see the give me strength thread)
Well, I am watching for Albert Ruiz to let us know his service department has found the problem. My own second try is Monday, July 1st. My first try resulted in having wheels balanced (failed) and then getting a service manager to ride along to actually feel and hear the problem. As a big shot in the dark, I removed my 4 splash guards, just in case wind catching them might cause a vibration. No luck - the problem is still there.No. I haven’t tried it in other modes. I’m hoping when I get it back the issue would have been resolved. But if not... I guess I’ll give that a try.
69-75 mph range
Or sympathetic vibrationit sounds like CV Joints hitting harmonic distortion.
I got my AWD and I don't seek to feel it. will get on a highway that is a little smoother and see if I can feel it.
