DMichaelHartley
- Jun 14, 2019
has anyone added a chip for improved performance? If yes what one did you install and are you happy with it
There are no performance chips available yet - at least not that I know of - but if you want a more responsive Telluride, this will do the trick:has anyone added a chip for improved performance? If yes what one did you install and are you happy with it
Following - Very interested, almost seems to good to be true!So i see its been awhile since someone inquired about a Performance chip. I actually don't have my Telluride yet. Just placed an order 2wks ago so should be here in 5months.
Anyone use this chip from PCT?
Stage 3 Performance Chip OBDII Module for KIA
Unlock your KIA's potential with the Stage 3 Performance Chip OBDII Module by JDM. Experience up to 40HP gain, improved acceleration, and better fuel economy—all with easy plug-and-play installation!www.performancechiptuning.com
Has anyone purchased this chip yet? I'm really curious if this works.So i see its been awhile since someone inquired about a Performance chip. I actually don't have my Telluride yet. Just placed an order 2wks ago so should be here in 5months.
Bingo. Your wasting your money to get anything out of a normally aspirated engine with a chip. If you have a custom engine built and your trying to tailor the engine management system to wring out the power, ok. A flat stock engine, no so much. It's all about that boost.My brother tunes everything and says without turbo or a supercharger you can't add alot of power.
I was thinking of eventually adding a cold air intake and a borla exhaust so I was curious if the tuning chip would help tune the ECU after they are installed.Bingo. Your wasting your money to get anything out of a normally aspirated engine with a chip. If you have a custom engine built and your trying to tailor the engine management system to wring out the power, ok. A flat stock engine, no so much. It's all about that boost.
You will be spending$1500 or more for what? 10-20 HP? Optimistically but I would only use before and after Dyno. Again spending more moneyI was thinking of eventually adding a cold air intake and a borla exhaust so I was curious if the tuning chip would help tune the ECU after they are installed.
Thanks for the feedback.You will be spending$1500 or more for what? 10-20 HP? Optimistically but I would only use before and after Dyno. Again spending more money
Got it. So I should swap out the stock engine for a turbocharged one.Agree with what’s been said, on a naturally aspirated engine you aren’t going to make much with bolt ons/chip unless you are willing to dig into the engine and mess with the compression, change out pistons/rods/cams etc. Then you’ll need a bigger throttle body, fuel pump, etc to feed it. Basically a new engine! And it will never end (in a fun way), you’ll always want to squeeze a bit more. It can be done and can be fun but you have to willing to literally pour money in because things will break as you test the limits. I built up a pretty rad NA Acura Integra back in the day but it took a crap ton to make it a couple seconds faster whereas others would throw on a turbo and get the same gain. Doh!
I have a turbocharged F150 and it’s sooo much easier…bigger turbos, bigger exhaust, tuner to up the boost and away you go with massive gains.
I wish I had the time and money to mod full time, it’s super interesting and is a great fun community.![]()
Or just add a turbo to the existing engine....S
Got it. So I should swap out the stock engine for a turbocharged one.![]()
