Tell-you-ride
- Jul 8, 2020
Bought a set of RGB footwell lights off eBay for 7 bucks. I used a "Add-a-circuit" to tap into an empty fuse slot which turns on when accessories turn on (otherwise it's normally off when the car is off).
Pretty happy with the result, the pictures look much brighter than it is in real life (modern phones are damn good at low light photos).
Provides just enough lighting in the footwell at 2% the cost of the Kia factory accessory as well as lighting up the back seats. I also get more light choices than that one
The module is controlled via a remote, but if I set it to a color/brightness I like, the module remembers that every time I turn it on/off again.
