Map Update v16.0 Arriving May 5th
Yeah, agreed. I think the interface for SXM is much better now. I just wish they would make the color scheme user-changeable.
Doing the upgrade presently. Seems to be much slower than previous ones. It's been over an hour and half and indication progress is not half way. Have it on a charger, hopefully will be done in the morning
All is well other than I have no clue how long it took. Ready to test it out.
I had to go through two updates that took a total of 2 hours and 20 mins. The second taking about 1.5 hours
Okay, so just to be clear, there are two updates? One for Nav and one for the Infotainment/Radio?
I'm still using the 3 panel and no purple haze ;)
I wish I had not done that update. I miss having (customizable) radio and maps (for speed limits) up at the same time. Maybe the new update is babysteps back to that.
My software version appears to be the one from October of 2021 (ends in 211006). Do I need to apply subsequent updates in order before applying this new update? Or can I just download the new update and install it and be on my way?
Remind me, does the vehicle need to be running the two hours?
Can anyone confirm that if this new update did something to the ambient light? Like give us an option to NOT dim down when shifted to drive ?
There’s one update for navigation units. Download it and install it… it’ll update your maps and apply the new features.
That was the second-most recent version until yesterday. But it wouldn’t have mattered even if your system hadn’t been updated for years… you just install the newest update available. It’s that simple.
Ambient light is the same as always. You can choose color and brightness. There is no option to change anything else. It will dim slightly in drive, there is no setting to change that.
That was the most recent version until yesterday. But it wouldn’t have mattered even if your system hadn’t been updated for years… you just install the newest update available. It’s that simple.
Thanks for the reply! I had seen people talking about November Updates so I thought there had been other updated after the October one.
Actually, my bad, I read October and then interpreted that as November for some reason. (Too much commenting on the last 24 hours about these updates!) So no, you didn’t have the most recent version (sorry). But like I said, it doesn’t matter. You just install the newest update.
Am I missing something? I don't see a audio update for the 2021 Telluride.
Good news is that update isn’t for you because as far as I can tell, you have navigation.
Also, the 2021 potentially isn’t listed because this isn’t really a new update because it first was released a long time ago (check those version numbers) and the 2021 LX and S already have it.
Downloaded to my computer, but I guess I need to go shopping for a bigger flash drive. The biggest I have is 32 Gb. It says I need 35 Gb. This must be a big update. (It took quite a while to download to my computer)
I had ignition on up the point of starting it. I then left a battery charger on it in case it kills the battery (It really shouldn't since there isn't that much draw but I have one). I know if you just leave it on accessories, it goes off after a short period of time.
