My satellite stations are much louder than the FM stations...anyone else experience this? Any way to fix?
Turning up the volume works. It's just annoying to constantly have to do this. I have another vehicle where volume between sources is the same.
The individual default volume levels for each input is in the sound setting menu..adjust them accordingly to your liking.
Short answer, no CD slot.Not unique. My Accord and Genesis are the same. Not all input sources are equal. I find CD to be the loudest. Does the KT even have a CD slot? That's so 15 years go.
Same issue with sound on my '22 EX, ANNOYINGNo default sound settings for fm and satellite.
Have done that and changed those various noise reduction settings, but still have the vast sound level difference between terrestrial radio and satellite radio. Minor gripe, but still a gripe. They could fix that with a infotainment system updateLook in the sound settings for three options that allows sound to be passed through in the original format, then , blocking some "noise" then blocking the "most noise"
If you go to Setup > Sound you do not see subsystem volumes?Same issue with sound on my '22 EX, ANNOYING
Subsystem Volumes is not listed in my Sound Settings as a subgroup. I have the standard system that comes with EX trim, not upgraded. Shouldn't matter, that should be a basic setting. Maybe that's changed in the new infotainment update, I haven't had time to install that yet. Thanks for posting that, though.If you go to Setup > Sound you do not see subsystem volumes?
Also keep in mind if you drive in an area with spotty HD radio signals, it will routinely switch back and forth between HD and SD radio. SD radio usually sounds lower volume compared to HD radio.
I have the April 2022 update. I checked my SXP today and realized I don’t have the System or Subsystem volumes settings either. Maybe they removed individual radio band volumes.Subsystem Volumes is not listed in my Sound Settings as a subgroup. I have the standard system that comes with EX trim, not upgraded. Shouldn't matter, that should be a basic setting. Maybe that's changed in the new infotainment update, I haven't had time to install that yet. Thanks for posting that, though.
