This may answer some of these Telluride issues on acceleration: "gasoline direct injection has a poor accelerator pump"
Low-Speed Pre-ignition
Low-speed pre-ignition is an issue usually associated with GDI engines. The problem here is that gasoline direct injection has a poor accelerator pump; you can find a carburetor having one or two accelerator pumps. So when you are at a high load, low-speed engine operation, and you push your throttle, it squirts more fuel through your accelerator pumps. During this condition, bits of carbon leave the valve and go into your combustion chamber, which finds its way to the cylinder wall, and is absorbed by the fuel and oil on the wall. As the piston shifts up, it transfers carbon particles to the crevice clearance, and these particles get diluted with oil and fuel, which smokes, causing low-speed pre-ignition.
Above may not have anything to do with acceleration but good to know:
Significant oil consumption
With the Gasoline Direct Injection system, the fuel squirts into the engine stick to the cylinder walls and mixes with the oil. So during combustion, the oil on the cylinder wall containing gasoline ignites and burns off. This is the primary reason why a lot of GDI engines are reported to have high
oil consumption.
Here's a link:
What Does GDI Mean on a Car? | Rx Mechanic
