Verde Axis 20x9 +38 satin black
Coopers discovery at3 4s 265/50R20
Sir any rubbing issues with this setup? Also planning to get 265/50/20s but probably gonna go with Toyo open country at III A/T
Yes there is some minor rubbing but as long as I'm not cranking it hard in either directions it's manageable. (y)
It may have been asked and I just don't see it, but what wheels are these?
I bought them thru Discount Tire were I also got my Michelin CrossClimate2's (265/60 R20) Tires. They are Shift Spring Custom rims (20X8.5 5-114.3).:cool:
I've been browsing discount tire. How are these working for you?
These are by far the best All Weather radial tires I have ever owned.. I live just of Minneapolis, MN and have been here since 1975.
Not much luck with the search function...anyone like to share pics (side view) of their Telluride with 255/60R18s?
Here are mine (wheels are from 2022+ Kia K5 GT Line and are 18" with +50.5 offset and 245/65R18 Michelin X-ICE winter tires) on 2023 Telluride SX-P (SX-Limited here in Canada).
I put the 22" Niche Gammas on as well back in January. I think 22" wheels are the perfect size if not doing much offroad, fills up the wheel well a lot better then the 20's. Went with the the Continental Extreme Contacts. The ride to us isn't noticeably rougher then the stock 20's. Went with 265 40 22. I like that the steering feels a bit heavier with the 22's. Performs in the snow just as well as the stock 20's, neither is great.
Looks awesome! I’ve been looking at this same set up. Any issues you’ve notice? Rubbing at full turn? I was thinking of the MS lowering springs too but not too sure if it would work with that tire set up.
I'm looking to buy a winter tire with braelin br10 + blizzak dmv2 265/45 r20?
Has anyone have/know using this setup? Any issues?
Wheel is 38 offset, just wondering if there will be rubbing with 265 width tires.
Got it installed on a 23xpro. No rubbing.
Braelin BR10 (Gloss Black) Wheels 20" x 9.0" 5/114.3 38 67.10
Blizzak dmv2 265 45 r20
Has anyone used the M&S lowering springs with 22"s successfully?
KMC Canyons black/grey, +35
BFG KO2 265/65/17
Eibach PRO Lift Kit (2" lift)
Eibach 1" PRO Spacers
(Yes, there's rubbing in the front tires at full clock only to either side... might be able to fix with help of a heat gun...)
M&S Lowering Springs
Savini SV-F2 22x9 +41mm
265/35R22
Howdy!
Thanks to my father's tow-truck business, and some poor driver's misfortune, I lucked into these beauties from a wreck for the low-low price of $200.
No idea what brand they are (no info on the inside and no center caps), but I did a test fitment and they appear to fit fine, though these are absolutely NOT the tires I'll be using lol.
They're 22x9.5... ET15 😬. That offset worries me a bit, but it LOOKS like they'd be ok. Considering 285/35/22 tires. If there's something I'm missing, please somebody let me know before I go out and buy these tires :LOL:. Thx in advance!
Anyway you can bolt them up and check for rubbing? You're gonna be close
