I'm in the process of installing a OEM 2022 hitch on a 2023 Telluride. Following the manufacturers instructions, I tightened the carriage bolts on the passenger side before tightening the 19mm bolts on the driver side.
When I went to tighten the 19mm bolts, I noticed a gap between the hitch and the frame. Is this normal? I haven't tightened the 19mm bolts yet because I was concerned about bending the frame. Perhaps the hitch will give a little bit and fill up that space, I'm just not sure.
Has anyone else noticed a gap on the driver side before tightening those bolts down?
