do you guys still have the car?All stock for me.
I gave up on it. KIA Canada is not like any other car company. They care more about their dealers than customers.
we tried like hell and fought with Kia for months about it. They would not sway from their stance that the issue was "bad tires" even after the tires were replaced with brand new tires and tested again. Techline will have the Kia repair technician running in circles trying all kinds of different stuff that just feels like a waste of time. Their field techs will use a vibration analyzer to assess the frequency of the vibration and then whatever their machine tells them they will stick to -- it's really pathetic because there's little to no analytical problem solving going on here. These guys and Techline won't assess a vehicle through process of elimination to determine the issue.
"our vibration machine tells us the issue is blah blah, so that's what it is. We don't care Mr Customer if you agree, now go away"
For whatever reason they're not too welcoming or willing to acknowledge this vibration is likely a bigger than what they believe it to be.
But does it make sense that it only happens at a certain speed range (natural frequency related)? I recently felt vibrations for the first time at @35K miles and it only happened at 65-75 mph with peak vibrations at near 70mph. If I avoided this range and car drove fine. Since this trip I had other long distance trips but I don't remember it happening again. People, does this issue come and go, or do you always feel it at ~70mph? Perhaps the imbalance worked itself out somehow after the long distance drive... ¯\_(ツ)_/¯The first thing to check when experiencing steering wheel vibration at speed, is to have the front wheels re-balanced. If that doesn't fix it then you'll have to dig deeper.
From my personal experience, tire/rim installation is critical. I have aftermarket rims in summer and I make sure to hand torque each bolt to 110 ftlbs (above the Kia recommended torque) in a star pattern. Every time the dealer changes the oil and checks the brakes, they reinstall with an impact wrench in any order and I have vibration in the steering wheel at 70 mph. If your tires are balanced, I would try hand torquing in a star pattern and see if helps (to 100 ftlbs if stock rims and 110 ftlbs if universal aftermarket).But does it make sense that it only happens at a certain speed range (natural frequency related)? I recently felt vibrations for the first time at @35K miles and it only happened at 65-75 mph with peak vibrations at near 70mph. If I avoided this range and car drove fine. Since this trip I had other long distance trips but I don't remember it happening again. People, does this issue come and go, or do you always feel it at ~70mph? Perhaps the imbalance worked itself out somehow after the long distance drive... ¯\_(ツ)_/¯
NOTE: I change my rims/tires between summer and winter, and rotate tires during this changeover. And this happened during the first long distance trip after the winter tire changeover.
Ours would come and go, and some days be worse than others. At first it was only noticeable at Highway speeds, as time went on you could notice it anywhere from 10 to 80 mphMy vibration is only on the steering wheel. The rest of the car seems fine. I drove it on the highway after work yesterday, and after I made my post above, and it seemed nearly gone. Plan to drive it a lot this weekend and evaluate more.
Talked to dealer and they plan to road test and rebalance tires. I’m hoping it’s just a balance issue.
Does yours come and go?
And is it more than just the steering wheel?
Any 2023s with this ?
Which trim/model do you have?My vibration is only on the steering wheel. The rest of the car seems fine. I drove it on the highway after work yesterday, and after I made my post above, and it seemed nearly gone. Plan to drive it a lot this weekend and evaluate more.
mentoredengineer.com
How's it been since getting the 23' ?
We just got rid of our 2021 for terrible vibrations and I'm super hesitant to try again on a 23' after the headaches we had dealing with Kia
Did you try to have the wheels road-force balanced (more precise than regular wheel balancing)? That's what I did to my 2022 after wheel balancing helped diminish but not fix the vibration from 63-73 mph. The mechanic at Kia also noticed the vibration and performed the road-force balance which eliminated the problem.Ours would come and go, and some days be worse than others. At first it was only noticeable at Highway speeds, as time went on you could notice it anywhere from 10 to 80 mph
For us you can always feel it in the steering wheel, in the sea, bottom and seat back and also in your feet. It's as if the entire car is just trembling like it's experience in many earthquake as it's driving down the road. A totally different sensation from a front end that needs to be rebalanced
Fantastic point. With 245 width low aspect 20” tires, road-force balancing is the way to go.Did you try to have the wheels road-force balanced (more precise than regular wheel balancing)? That's what I did to my 2022 after wheel balancing helped diminish but not fix the vibration from 63-73 mph. The mechanic at Kia also noticed the vibration and performed the road-force balance which eliminated the problem.
No cost. The Kia dealer should be assessing all of that at no charge if your vehicle is still under OEM warranty which yours sounds like it is.How much did it cost you guys to have the problem associated with the vibration tsb investigated? I have a 2020 ex awd with 51K miles and it is getting very bad.
Thanks for that. I dread having to deal with them, but I'm doing my best to document the problem.No cost. The Kia dealer should be assessing all of that at no charge if your vehicle is still under OEM warranty which yours sounds like it is.
Just be prepared for Kia HQ and Techline to possibly fight you tooth & nail over it
Do it sooner rather than later. You don't want to cross the 60k mile mark an old then they try to use that as an excuse you're out of the warranty windowThanks for that. I dread having to deal with them, but I'm doing my best to document the problem.
so, it is fixed in 2023. I am thinking about placing a order for 2023 EX AWD and trade in 2022 EX FWD.It has actually been really great. We've had no issues and are enjoying the new/upgraded tech & the change in color.
I was super paranoid as well, and the only thing that convinced me to do it was that I trusted the dealer to make things right if needed. I was willing to pay a markup to work specifically with that dealer.
there are owners with 23' model year vehicles that have experienced the same issues. I don't think they've fully got a handle on the issue yetso, it is fixed in 2023. I am thinking about placing a order for 2023 EX AWD and trade in 2022 EX FWD.
