Nac
- Aug 24, 2020
"I think ISG is designed to not kick in when battery reached a certain charged but still far from being discharged!"Hmm, so can we deduce that when ISG works, the battery is at 100% charged? But it stops working if battery is less than 100% charged? But that will be a very high parameter. How about say 80% charged —when there is still ample power to restart the car (to avoid being stranded)? I think ISG is designed to not kick in when battery reached a certain charged but still far from being discharged! Maybe they left a wide enough berth to avoid further discharging the battery (despite enough charge left—like 80 or 70%) in anticipation of more start and go that will lead to depletion of battery resulting to failure to start (stranded)! With this theory, we can then deduce that if ISG stops working, it doesn’t necessarily mean battery is going bad (tho it could be)—it just doesn’t meet the battery criteria. But if ISG is working, we can be assured that the battery is in excellent shape! In a way, ISG then is a good indicator of the state of charge of the battery! Just my two cents! Thanks!
Very nice reasoning regarding the ISG disable battery level. It may have been easier to read the Kia chart above that states:
Battery condition Charge/Discharge performance SOC (SOC = State of Charge) > 68%
"If ISG is working, we can be assured that the battery is in excellent shape! In a way, ISG then is a good indicator of the state of charge of the battery!"
I would not say ISG shows the battery is in excellent condition; I would say ISG shows the battery is in adequate condition to accept and hold a charge greater than 68% (enough to allow repeated starting of the engine according to Kia engineers).
I would not consider a battery able to charge only to 70% to be in excellent condition. ISG working indicates greater than 68% battery charge, unfortunately ISG can not tell how much higher than 68% it is.
