USB-C charging options for iPhone 13
ABRTelly
Anyone have any luck finding a way to charge a newer iPhone via USB-C cord?
You’d have to find a 12v plug with a USB-C port, or you would have to use your normal brick with the household outlet in the 2nd row if you have an SX with Prestige package. Otherwise, just use a good old USB-A cord.
Also, you can charge your iphone by putting it in the front tray-camera side down. An amber light will come on so you know it is charging.
A converter/coupler also works if you don’t mind charging at the old 5 watt rate.
USB C Female to USB Male Adapter 2 Pack,Type A Charger Cable Power Converter for Apple iWatch Watch Series 7 SE,iPhone 11 12 13 Pro Max,Airpods iPad Air 4 Mini 6,Samsung Galaxy Note 10 20 S20 S21 FE Amazon.com
Just buy a regular USB to Lighting cable
Not 100% sure on the question here but will try and clear things up.
Current iPhones that support faster charging use a Lightning to USB-C cable, but they will also charge with a Lightning to USB-A cable, just at the rated wattage of the USB port.
This previous thread from a year ago described the charging rate of the USB ports, which is pretty standard for a slow USB charger - 5 watts. The older "cube" style iPhone charging bricks and any crappy charging brick you'd pick up at a gas station will max at about 5 watts:
Short answer - a USB-A to lightning cable will be just as effective as a USB-A to USB-C adapter, with a USB-C to lightning cable.
As @bruesjoh04 said, you'll need a separate 12v charger to hit a faster charging rate.
it’s called a usb-c cable… get one that has the i phone one one end an usb-c on the other!!!! just bought one at Dollar General!!!
Dude - you missed the point. The original post was in 2022. 2022's and earlier models (I don't know about 23's) do not have a USB-C port so your solution will not work. That is why the talk of adapters and USB-A cables.......
Limited-time deal: Meagoes USB C Car Charger, 36W 2-Port Fast Charging Adapter with PD&QC3.0 Compatible for Samsung Galaxy S23/S22/S21/S20 Plus/Ultra/S10/S9/Note 20/10, iPad Pro, Google Pixel 6/5/4-3.3ft Type C Cord https://a.co/d/b3vQO55
Just got this. It actually activates "super fast charging " on my S21. I know it's not an iPhone but I would expect maximum charging with this also.
oops, sorry thought she was asking about a 23 which does have usb-c ports all over … oddly only one usb standard port up front!!!
