I started with of course our local retailer chain in Seattle, ($$$$ Car Toys $$$$), then Crutchfield (MSRP)....
However, purchased most of the components from
Abt Electronics, who beat out Crutchfield prices by a significant margin. Do not consider skipping the SoundShield Mats or the Black Hole Tiles. Accoustical treatments are a must. All four doors and the cargo hatch door should be treated.
Some items did come from Crutchfield, such as wiring harnesses, etc, some came from Amazon, and Sounds Good Stereo for the Black Hole Absorption Tiles. Do not buy the Wavetech Link8 LOC on eBay, (which has the older obsolete version). You need the latest generation, so buy from Wavetech Link8 from Crutchfield.
For steep discounts:
Louie Igyarto
Abt Electronics
(847) 544-2652
louis.igyarto@abt.com
- JL Audio XDM800/8 Channel amp.
- Wavtech Link8 (LOC) Line Output Converter/Processor.
- Focal 165AS component integrated speakers (pair) for front doors, (woofer and tweeter).
- Focal 165AS component integrated speakers (pair) for rear doors, (woofer and tweeter).
- JL Audio Evolution 3.5" Coaxial Speakers (Pair). Mid-range Speakers for rear surround.
- Focal P 20 FSE 8” Shallow Sub.
- JL Audio HD-RLC, HD Amp Remote Level Control and Cable.
- SoundShield Car Sound Deadening Door Kit Mats - 5 Rolls. This covers all four doors and Rear Hatch.
- Blackhole High Efficiency Accoustical Absorption Tiles ~ 40 pack of Foam Tiles. This covers all four doors.
- Wire Bundle Kit for amp with Fuses.
- 4-gauge dual amplifier wiring kit — includes power wiring.
- Wiring Kit for Processors and Low-Current Devices, which includes 18-gauge power and ground wires (25-foot), fuse holders, and fuses.
- QTY 2 EA: American International HKSB110 (= 4 total Speaker Adapter Brackets).
- QTY 3 EA: Metra 72-7302 Speaker Wiring Harnesses (=6 total Speaker Harnesses). Front Row, 2nd Row, and 3rd Row mid-range speakers, (rear surround).
I then had my local guy, (installation) install everything, (labor only). Did not use Car Toys, but a local independent shop.
Customer Own Gear, (COG).
The above list is a result of dozen and dozen of hours of research.
Yes, you are correct.
Crutchfield could only identify the front and rear, meaning the Focal 165AS Component Integration.
Crutchfield had nothing on what the Rear Surrounds are, (third row) or what the subwoofer is.
The only way to determine what the Sub Woofer area is and the Side Rear Surrounds is your local installer. Since my project is done...you have experience from me. If you use the shopping list above....you will save so much time.
I'll save you time and troubleshooting,
as you must go with:
- JL Audio Evolution 3.5" Coaxial Speakers (Pair). Mid-range Speakers for rear surrounds.
- Have your local guy build a custom box for the Focal P 20 FSE 8” Shallow Sub. DO NOT MOUNT THE NEW SUB IN THE FACTORY LOCATION. The factor shallow sub is integrated in plastic! It's the worst of the worst. You must have your guy build a new box, and place it in the storage compartment hatch floor, in the rear cargo floor.
If you do the above, with these components.....your system will blow you away. Absolutely blow you away.
