I just sent the following message to their headquarters...
Hi James, I'm hoping you can help me.
My family and I have been considering a few different vehicles to tow a trailer.
I currently own a Kia stinger, which I absolutely love, and we own a 2013 Honda Odyssey which we're looking to upgrade.
We are looking at the Kia Telluride (Preferred) and the Honda Pilot.
The pilot is rated for 5000 lb towing capacity and a 500 lb tongue limit.
The Kia Telluride is rated at a 5000 lb towing capacity and a 351 lb tongue limit.
According to the KIA Telluride manual, it's saying that you can never exceed a tongue weight of 10% of whatever it is you're carrying.
So if I work the numbers backwards on that, that means I should only be able to safely carry 3500 lbs. Because 10% of 3500 lb is a 350 lb tongue weight.
I'm trying to understand why exactly you guys would rate a vehicle for a 5,000lb tow with a 7% tongue limit (351 lbs)?
If I was to tow a vehicle loaded like that, it would be completely unbalanced and might cause a crash.
Your tongue limit is always supposed to be 10% of your towing capacity. So 10% of 5000 is exactly 500 pounds. That's all within normal specs within the towing community.
If you're not quite as familiar with the towing world, here's the reasoning....
Manufacturers have a tongue weight limit because if you put too much weight on the tongue...
- Your suspension may not support the extra weight and cause the vehicle to sag to the floor
- It could also tweak the frame then the doors don't close quite right
- The tires can also pop if they're too heavily loaded
- The Trailer hitch may break
Proper trailer balancing is also extremely important. If there's not enough weight on the trailer tongue it can cause major trailer sway.
That's why you guys require (per the manual) the 10% balancing limit. So theoretically, if you've got a 5000 pound load behind you, to properly balance you need 500 lb in front of you on the trailer tongue.
If I was to load up a 5,000 pound load behind me and only put 350 lb on the trailer tongue - that means I would be unbalanced and the trailer could sway and move very unsafely.
I have been all over the internet, I have been on forums, I have talked to the service advisors, I have also talked with dealerships, I've called your corporate office, and no one can seem to help answer this question.
I'm just trying to understand the mechanics or the science behind your combination of specs?
Is the current trailer tongue weight based on the factory-installed hitch or is it based on the frame weight capacity of the vehicle?
I'm just trying to figure out how I can safely tow 5000 lbs. Can you please advise? it'll really help me make a decision as to whether or not the Telluride is right for our family.
Thank you.
