Sir any rubbing issues with this setup? Also planning to get 265/50/20s but probably gonna go with Toyo open country at III A/TVerde Axis 20x9 +38 satin black
Coopers discovery at3 4s 265/50R20
It may have been asked and I just don't see it, but what wheels are these?
One more for the files.
20x8.5 +38 Drag DR-73
255/50-20 Firestone Destination LE3
Yes there is some minor rubbing but as long as I'm not cranking it hard in either directions it's manageable.Sir any rubbing issues with this setup? Also planning to get 265/50/20s but probably gonna go with Toyo open country at III A/T
Yes there is some minor rubbing but as long as I'm not cranking it hard in either directions it's manageable.![]()
I bought them thru Discount Tire were I also got my Michelin CrossClimate2's (265/60 R20) Tires. They are Shift Spring Custom rims (20X8.5 5-114.3).It may have been asked and I just don't see it, but what wheels are these?
These are by far the best All Weather radial tires I have ever owned.. I live just of Minneapolis, MN and have been here since 1975.I've been browsing discount tire. How are these working for you?
same here 2023 sx and cant stand the rimshey guys! I purchased the EX model and cant stand the silver OEM rims. Any luck finding any links to wheels?
Looks awesome! I’ve been looking at this same set up. Any issues you’ve notice? Rubbing at full turn? I was thinking of the MS lowering springs too but not too sure if it would work with that tire set up.I put the 22" Niche Gammas on as well back in January. I think 22" wheels are the perfect size if not doing much offroad, fills up the wheel well a lot better then the 20's. Went with the the Continental Extreme Contacts. The ride to us isn't noticeably rougher then the stock 20's. Went with 265 40 22. I like that the steering feels a bit heavier with the 22's. Performs in the snow just as well as the stock 20's, neither is great.
Got it installed on a 23xpro. No rubbing.I'm looking to buy a winter tire with braelin br10 + blizzak dmv2 265/45 r20?
Has anyone have/know using this setup? Any issues?
Wheel is 38 offset, just wondering if there will be rubbing with 265 width tires.
