Has anybody tried to retrofit led lights from the SX into the EX?
I don’t think that is easily accomplished. The factory equipped LED projector option has additional electrical installed. A cheaper alternative that has been discussed is using a direct replacement LED bulb with electrical current regulator that fits in the projector housing for the HID bulb in the lower trims. The challenge is getting the LED direct replacement to project as well as the HID for distance. Someone on that other thread did say they took their Telluride to a local LED lighting store to have lights professionally installed. It could just be a matter of finding the right LED bulb replacement and turning it just right in the housing of the projector to reach as far as the HID with no dark spots.Has anybody tried to retrofit led lights from the SX into the EX?
How is Kia corporate OK with so many of their dealers having a reputation for pulling this above-MSRP crap? I love my Telluride, but the dealer experience really leaves a bad taste in my mouth. No other consumer product sells above MSRP from the original seller. It's especially atrocious since we are a captive audience who can't buy a new Kia from anyone other than a dealer (competition among dealers doesn't count in my book).
I agree that a good quality aftermarket HID bulb might still have benefits over LED. Other than the life to replacement that you gain with LED I think HID can come in a whiter color if that’s what you want but you get the distance forward range (without requiring fine tuned adjustment) that is lacking in the LEDs. I think the challenge is that projector lamps designed for HID are made for a 360deg bulb. But the LEDs are 2 sided and create a dark spot that has to be overcome by turning it just right and hoping that the projector gets the LED as far straight as the HID. So the LED is great to light up right in front of your bumper or blind the driver in front of you, but adding more lumens directly in front of you does not always help for distance at night. Most of the more expensive LEDs are more lumens but I don’t think that’s what I want if I can’t get the distance.Honestly I put an aftermarket HID in my 2018 Sorento EX with projectors and it was night and day. No issues with overheating inside the headlamp assembly, but I did have to Dremel a small hole to let wires out. No shadows or weird lighting.
Honestly would do the same if I didn't have an SX.
Thank you! I had seen zdatts discussed in the other thread but didn’t realize they are 4 sided. Everyone is raving about the Hikaris and the Sealights. I might just try the zdatts since they are so low in price. I think the Telluride needs HB3 9005? https://www.amazon.com/14400LM-Head...Year+Warranty&qid=1564675477&s=gateway&sr=8-1I had 4 sided LED's in my Sorento and gave great light output over the
Watch a YouTube video before you shell out $50-$100 bucks for a store to do them. LED will be just like changing the bulb, just bigger. HIDs take a little more. Where do you live?
I decided not to buy anything yet after looking at the Zdatts, Hikaris, or Sealights. I started trying to understand why something like the Diode Dynamics 9005 SL1 were SO MUCH more expensive. It appears that the more expensive led bulbs claim to be engineered to be precisely measured equivalents to match the standard 9005 HB3 bulbs exact figment for the OEM projector housing to maximize range and reduce glare by putting the led diode in the ideal spot to mimic the halogen bulb. Not ready to pull the trigger on $150 to experiment with a bulb just yet.read the reviews on the zdatts on amazon, not so good, Hikaris a little better, Sealight new generation with 3 year warranty customer reviews has the most positive also the most expensive. not being handy, where should I go to have them installed?
Did you ever try the SL1s? Not sure buying the SX over EX makes sense if all I want is bright headlights...I decided not to buy anything yet after looking at the Zdatts, Hikaris, or Sealights. I started trying to understand why something like the Diode Dynamics 9005 SL1 were SO MUCH more expensive. It appears that the more expensive led bulbs claim to be engineered to be precisely measured equivalents to match the standard 9005 HB3 bulbs exact figment for the OEM projector housing to maximize range and reduce glare by putting the led diode in the ideal spot to mimic the halogen bulb. Not ready to pull the trigger on $150 to experiment with a bulb just yet.
