yanivc
Hi, could you possible reply with the model number of the bulbs you purchased? I hate how the backup camera looks at night and this is exactly what I want to do. Thanks!Just got done doing the reverse and backups. Why? I don't know I'm a sucker for group pressure and like tasks.I purchased Sylvania bulbs from the Autostore. Probably paid a little more but I have had mixed luck with Amazon brands before just not lasting. The reverse light wasn't an issue. They don't give you much room to work with and the Sylvania bulbs have a direction they are placed. Plugged in the wrong way to wont work. Just test before reassembly. There also is a right and left assembly for the cover lens. They wont go in if reversed. For the back ups, getting the handle off was trickier than I thought. When you pull down the cover, its hard not to have all the clips not come undone. When this happens, it tips down and a cable in the top passenger's side slides up to block it going back as it was originally. If you notice all the clips are sitting below the holes, this is the problem. You also need to put the whole cover back at the same time. I was trying to visualize the clips going into the ones in the center but the process of pushing it down to see it distorts it and miss-aligns. You can see a few around the periphery and align these. Once together you can push in the center and hope to hear it set.
